redline4
I'm huge in Japan
- 2:49 PM
- Mar 12, 2018
- Rosholt Wisconsin
That’s awesome !!Was thinking the shifter was going to be an issue but it fit like it was made to be. The 5 speed shifter came through the old TCase shifter hole, the shifter boot even fits.
Bubba's 85 Squarebody.
Turns left just fine. Refuses to turn back to the right. We tried a different power steering pump. No change. Unhooked the stabilizers that he installed.....no change. Was working fine till yesterday afternoon. We're thinking the steering gear is fubared. Thoughts?
Vacuum brakes.I know we talked brakes on it..
Hydroboost or vacuum?
He lifted it. Make sure linkage isn't binding or over centering.
All 4 on the way.....and a ball joint press. We're gonna have a million bucks in this truck. LOLBall joints will do that. Lucky it didn't happen on the road. It gets exciting when the steering doesn't center itself, when you don't expect it.
I would change all 4 as they have a tendency to tighten up.
Yea maybe the first one is expensive to get going properly, after that with having all them fancy tools you'll be doing it in your snoozing/ sleeps. You know repetition makes it easy, JUST LIKE chainsaws.All 4 on the way.....and a ball joint press. We're gonna have a million bucks in this truck. LOL
True story. I never mind buying tools though.Yea maybe the first one is expensive to get going properly, after that with having all them fancy tools you'll be doing it in your snoozing/ sleeps. You know repetition makes it easy, JUST LIKE chainsaws.
Been there done that a few to many times to count. Some of those infrequently used tool (sets) take up a fair amount of room, leaving one corner of the garage a bit "cluttered" some weeks.True story. I never mind buying tools though.
I can see it being great for u-joints !!!At least 10 years ago, my dad was quoted 1200.00 to have ball joints replaced on his '96. 100.00 for the press and a set of Moog joints and we were golden. Using it for u-joints works better than anything else I got too.
It’s a square body…All 4 on the way.....and a ball joint press. We're gonna have a million bucks in this truck. LOL
For sure. If you've never used those before, I've found that putting the ball joint under compression with the tool and tapping the control arm helps them come out easier than full on forcing them out with the press.True story. I never mind buying tools though.
Good info. Thank you.For sure. If you've never used those before, I've found that putting the ball joint under compression with the tool and tapping the control arm helps them come out easier than full on forcing them out with the press.
I didn't do the compression first, then tap the control arm once, but got lucky and avoided harm. Great learning experience, but a little too close for comfort.
