tree monkey
- 11:33 PM
- Dec 14, 2015
- wi
Piston should be backwards cause of fingers. No?
yes
the lower rod bearing is bigger on the 660's then the 066's.
the rod has gotten hot and has lost is temper, will likely fail sooner then later
awesome port work, just awsome
gee, he went nuts on this one.View attachment 88519
I'm going to guess no one will answer that one.gee, he went nuts on this one.
Out of curriosity, is there any on this forum who still has contact with Jason?
I pulled a brand new 660 short block down that had blue ends on the rod. Never been run besides the factory. Looked similar. If the bearing cage has wear between the rollers then I'd chunk it.the lower rod bearing is bigger on the 660's then the 066's.
i doubt myself that any will confirm that they're still on toutch with himI'm going to guess no one will answer that one.
Yeah I was thinking the same thing.Good grief. It does pile up...
Is this one going to need a new jug too? Those fingers look like they're in the path of the ring ends.
It's just from the Stihl ultra...I pulled a brand new 660 short block down that had blue ends on the rod. Never been run besides the factory. Looked similar. If the bearing cage has wear between the rollers then I'd chunk it.
