even more jmssaws *B-S....
tree monkey
1:53 PM
wi
just where the hell does one start.
Little more history or what I was told. Is/was a original redlight saw. He changed cases on it so he could run the bigger bearings/poly flywheel. Other then Supposed having new oem piston and rings when I got it he never told me anything else about it.
so now it's a ms660 with a red light tank. red light no longer works.
tree monkey
1:53 PM
wi
bar plate junk, missing dog screw
why drill the cover when using the old style studs? and not drilled deep enough for the new style studs.
no need to remove those
missing handle screw
surprise surprise
jacob j.
Lord of Cargo Pants
11:53 AM
Coastal Oregon
Jason's made that claim in the past, but the bearings between all 066/MS-650/MS-660 saws are the same dimensions. The part numbers have changed only because Stihl has changed suppliers several times and they've changed the configuration of the bearings, but not the sizes. Of course the flywheel side seal changed dimensions because the poly flywheel crank has a larger stub shaft on the flywheel side.
There were a handful of the earliest 064 saws that used a 6202 size bearing on the flywheel side but according to the NW Stihl technical rep, those saws were only sold in Europe.
Just curious- is the big end rod bearing shot or would the crank need replaced due to discoloration on the rod?
tree monkey
1:53 PM
wi
the lower rod bearing is bigger on the 660's then the 066's.
the rod has gotten hot and has lost is temper, will likely fail sooner then later
