Echo cs 590,600,620 porting/mod/build thread
bmwpowere36m3
10:42 PM
CT
MM Options
1. Removal of inner plate in deflector (very easy, done)
2. Removal of entire rear flat plate under deflector (easy). Based on reports, bad idea and obnoxious noise levels. Straight shot from exhaust port.
3. Drilling holes either around exit tube and/or rear flat plate 1/2" max (under deflector)
OR
bmwpowere36m3
10:42 PM
CT
continued...
4. Removal or exit tube/gutting
20150626_140927.jpg uploadfromtaptalk1416637260752.jpg uploadfromtaptalk1431664999770.jpg
5. Additional port
6. Combinations of above.
No pictures
Red97
10:42 PM
MI
1,6 going to be the quietest option...
bmwpowere36m3
10:42 PM
CT
I posted in your other thread as well.
The 590,600,620 while being almost identical on the outside.
The timing in the jugs is different, only slightly on the 590-600 quite a bit on the 620.
Imo the 590/600 won't gain anything measuable from just a gasket delete.
Getting the tune dialed in, will show more of a gain in the wood.
These get nasty loud in a hurry, I would do just a 1/4-5/16 hole in the flat under the tube if you are worried about the noise. Should be a good compromise. Noise vs flow.
Yup saw it, are most of you guys on both? So option 3, second pic but ~1/4 hole?
10:42 PM
Never modded an echo, but I like noise. I'd gut the whole thing and make an exit hole the size of the cylinder exhaust port. I might die deaf, but I had fun doing it
bmwpowere36m3
10:42 PM
CT
I always wear ear plugs anyway... but living in "suburbia", I like to be somewhat considerate of my neighbors. Even if most of them are deaf... I mean old ;)
RedFir Down
8:42 PM
Idaho
Like Red97 and others have said these series for Echo's get truly obnoxious in a hurry.
Picture's # 2 and the last 2 on #4 are what I posted on A.S. and I will tell you they are stupid loud. Extremely raspy and just a crude tone.
I have modded about 7-8 of these muffler's and anymore I just pull the bottom deflector out and call it good.
One of the last muffler I did I got curious and drilled 2 holes (just under a 1/4" each) near the front side of the exit tube and it really didn't change the volume (I was at dads with 2 new 590's cutting/tuning and he said they sounded the same. The bottom deflector removed, vs. 2 small holes muffler) of the saw and I couldn't tell a power difference either.
I'll post a picture in a minute.
Larry Joe
7:42 PM
Northern California
I did #3 first picture with larger holes, it improved flow and gave the saw a mellow growl . I think the best thing you can do to them is trim the tabs , open the can to your liking then run the hell out of it. They get better by the gallon.
bikemike
9:42 PM
Cottage grove mn
Very true. They are slow to break inn and it's very frustrating. Some patients and good things will come
bikemike
9:42 PM
Cottage grove mn
MM Options
OR
Ok with all that you tried for performance, and noise levels what pic was the most effective for the power gain and lower noise level?
10:42 PM
number 4 at the top of the page made the most noticeable difference i did it in increments to 3/8 but i have not tried a dual port i have another 590 I'm going to try that on my new one.
10:42 PM
Louder but bearable.
bmwpowere36m3
10:42 PM
CT
I've only done the inner deflector... but the saws been put away for now. Working a 034 for my dad.
bikemike
9:42 PM
Cottage grove mn
I did a nice mm to cs510 a while back. Cut it in half removal of deflector and stock exit tube and installed a bigger ID exit tube it was a bit louder but made some great torque and rpm. The muffler cracked where it mates to the jug after a while when 1 screw came loose and didn't notice it. So I piped it
