psuiewalsh
Basement Bodging
- 8:53 AM
- Dec 23, 2015
- Nottingham,pa
I've already changed plugs with a new one. It will run for a couple noodle cuts then die. Then it will crank up then die. Does the same without the vent installed. Fuel line holds vac and flows fine. I changed the valve sheet in he carb with a tan one. No change. I don't have a new diaphragm but it doesn't leak either.
