- 9:08 PM
- Jun 5, 2016
- Northwoods of Wisconsin
I want to weld this so it doesn’t break off. I have a stick welder. Can I make it work?
Yes.
Yes.
Never mind. I just noticed it's a husky cylinder
TIG or leave it be. If you don't get the amperage right you will blow thru that fin in a split second with stick. And you have to move FAST running an aluminum rod. I haven't run an stick aluminum rod in a LONG time but it deposits fast.
Is there special rod for it, or any piece of aluminum will work?
Like steve said it's the heat man. Back it up with thick copper sheet if you try to weld it with a stick.Is there special rod for it, or any piece of aluminum will work?
Boy that looks familiar
Sure don't
