Cerberus
Cerberus the aardvark, not the hell-hound!!
- 11:13 AM
- Jan 20, 2020
- Florida (tampa area)
I aim to run my saws "optimal", I rarely err towards fat/lean, however my understanding is it's smarter to run a new/out-of-box saw a bit fat (and w/ extra oil)
My problem is that the carb's limiter-caps are such that, out-of-box, my carb's H&L were already both almost max'd out (fully CCW turned as far as *limiter caps* allow)
I did add a splash of HP Ultra to the echo canned-fuel I got for this 590 (for its first tanks, then it'll get the usual eth-free 95oc//HP Ultra//Stabil 45:1 mix I use on everything else), but I cannot get it out of my head that EVEN WITH the H&L at max, *because of the limiters*, that it's still too-lean....IE when playing with L while the saw is idling, and wanting to do the "back & forth" with the L screw to hear the "upper & lower thresholds" before setting it in that sweet-spot, I cannot richen it too-much to cause rough idling, the limiter gets in the way....
I'm guessing I know the answer but....I should NOT go cutting wood with this UNTIL I have removed the limiters and verified, by moving L both to the too-fat, then too-lean, then sweet-spot, that w/o that I should not even be considering taking this saw to a job yet?
Thanks a ton for insight, am at an odd position because my gut says that if the limiter prevents me from going too-rich, then I cannot really know if I'm actually at the sweet-spot, the sweet spot could be like 1/16th or more *past* the limiter and I'd never know because I cannot do the too-rich / too-lean "back&forthing" to set it!
(PS-- any tips on removing the limiters would be appreciated, I know last year I tried the "hot needle, then pull it out" trick on my 355T's limiters and it did not work I had to remove them in like dozens of lil pieces )
((PPS-- off topic but if anyone knows off-hand, I'd love to know if the 620's handlebars are a "plug&play" replacement for the 590?))
