Compression testing
jmssaws
Banneded
5:11 AM
I build high compression saws and settled on one tester and don't worry about it.
Redfin
Meh...
6:11 AM
Central Pa
I love this thread. These compression reading are just a reference. It is only a static reading. Too much variance with hot or cold. How much oil you run. What altitude your at. But one thing for sure is the Internet likes some compression.
@Redfin thanks for taking the time on your end. The results are not deniable.
This thread was meant for nothing more than the hose adding volume debate. Who friggin knows I may have mucked something up and its wrong.
jmssaws
Banneded
5:11 AM
My 034 is 225,got a 066 and a 394 that are 240,another 066 that's 230. My 064 hybrid is 225.
Stihlbro
6:11 AM
Virginia
So how accurate is your gauge? Have you ever qualified it? How much is high compression? And why do you find it necessary? I'm curious?
czar800
6:11 AM
Ellwood City
How does it run, how does it cut/ tune?
There's a video in my thread (Stihl 026 rebuild). I would love to here what you guys think!! The 024 feels stronger. I don't want to high jack this thread.
tree monkey
5:11 AM
wi
I thought that saw with over 300 took a chit?
witch one? 440 head saw lost a crank real quick like.
361 was the first saw I was able to get to detonate, lowered comp by raising exhaust port. still runs fine.
jmssaws
Banneded
5:11 AM
I don't care if my guage is right or not.
It's consistent so I use it. It probably ain't right but it don't matter since it's the only one I use.
Stihlbro
6:11 AM
Virginia
Your test is valid. You did nothing wrong. I've found the same results. So now when you post a compression reading, should a person state what length hose used? How many pulls to achieve highest reading? Please don't take my post wrong, it's not what you did at all.
Joey
jmssaws
Banneded
5:11 AM
I've never had a problem with high compression.
Stihlbro
6:11 AM
Virginia
So it is ok to say a high compression saw is what is needed to perform? The higher the better right?
jmssaws
Banneded
5:11 AM
I don't know if that's true,I've found the higher the better but it's not necessary.
Strongest 066 I've ever ran was 230lb,but I got one that's close to it at 220.
