- 2:12 AM
- Apr 13, 2020
- 5543X, 5644X
My old tester bit the dust.
I'm seeing these 2 tester kits available locally, OTC 5606 and Mityvac MV5530.
Both have 10mm, 12mm, 14mm, and 18mm plug adapters and come with storage cases. Noted differences that I see from sell information is the OTC has a 25" flex hose attached to the gauge then adapters and the MV has a gauge attached to a 10" hose that then attaches to another 6" or 12" hose and then to the adapters.
It will get used for small engines and auto's as well.
If you have one of these models have you had an issue with it that would make you look for something different in the future?
The mityvac mv5520 is also available but only comes with 14mm and 18mm adapters and no case.
What do ya think folks???
