Redfin
Meh...
- 10:10 PM
- Dec 24, 2015
- Central Pa
In some other thread we have been chatting about the length of hose connected before the gauge. Here is what I found.
I used my Mityvac comp tester with two different lengths of hose one being roughly 6" and the other 12".
The saw is my 446 which has been 205 psi since forever. The saw was drained of fuel and idled dry for comparison. I used the short 6" length and pulled probably 10 times to make sure it was at max comp. I then released and counted the pulls to get to max. It took 6 pulls to get to 205 psi.
I then attached the 12" hose and pulled 6 times I ended up at 175 psi.
I released the pressure and pulled until the gauge stopped which was 205 psi and it took 12 pulls. This verified in my noodle if the schrader is at the tip in the combustion chamber and its functioning correctly the length of hose once filled does not add to chamber volume.
