- 1:04 PM
- Dec 28, 2015
- Central Ohio
It is indeed a Boost port motor and at one time i had a note that they might be 2mm larger than the 60/61/62/65/655 but they measure the same on the calipers at least the two i have found to check myself.The Target saw is a boost port if I remember correctly. Curious to see how that one runs. Does it have a separate oil tank like a normal chainsaw?
the boost port is so different from modern boost ports, so dang simple
it has the same crankcase assembly but a different clutch cover and the case divider for the oil tank isn't there and the oil filler hole is not knocked out but looks like it will come out and thread easily
The demo saw has a great base plate that protects the bottom of the saw and a different baby blue paint job
