Like I said I haven't got it yet so we will see.Well sheet.
Hopefully you get what you're expecting.Like I said I haven't got it yet so we will see.
Mine may show up grey too Jim but I dunno. If it shows up black then I'd like to do an even swap for they grey one since Clint saw is getting restored.He lied to me and then sold that one to you days later. I don't think you beat anyone to the punch.
I do believe I deleted that before you replied!, lol.Mine may show up grey too Jim but I dunno. If it shows up black then I'd like to do an even swap for they grey one since Clint saw is getting restored.
Ok sounds good. Clint is a good guy and I like to help when I can. Sorry if I was being a dick I was just excited I may get a black one. So what are you thinking on the port work?I do believe I deleted that before you replied!, lol.
I have some black tubing on its way so I can change out the grey. No need to make any sacrifices.
He likes running longer bars so I'm going to target the low end torque. It might want a thicker or stronger reed petal for that.Ok sounds good. Clint is a good guy and I like to help when I can. Sorry if I was being a dick I was just excited I may get a black one. So what are you thinking on the port work?
I got the 2 stage reeds from boyesens.He likes running longer bars so I'm going to target the low end torque. It might want a thicker or stronger reed petal for that.
Curious to hear how this works out and what tubing you used.I do believe I deleted that before you replied!, lol.
I think the tubing is from stihl.Curious to hear how this works out and what tubing you used.
Where did you order them from?I got the 2 stage reeds from boyesens.
I'm impressed bish not to bad at all.Boyesen.com has their phone number. They don't have the reeds advertised on the site but if you give them a call they are part # 801
Your good to go then on reedsI already bought and installed the Boyeson reeds on this saw... I kinda jumped the gun a little bit, seeing as how the saw needed new crank bearings.
I noticed those and I think they're a good looking set up. I'd like to see the difference in performance between those and the two stage set I fabricated. My secondary petal looks like it may be quite a bit softer than the Boyesen.I already bought and installed the Boyeson reeds on this saw... I kinda jumped the gun a little bit, seeing as how the saw needed new crank bearings.
I still have the stock ones laying around here somewhere, too...I noticed those and I think they're a good looking set up. I'd like to see the difference in performance between those and the two stage set I fabricated. My secondary petal looks like it may be quite a bit softer than the Boyesen.
I'm new to the reed valves. What would the softer reed do? I know my stock one was thin metal.I noticed those and I think they're a good looking set up. I'd like to see the difference in performance between those and the two stage set I fabricated. My secondary petal looks like it may be quite a bit softer than the Boyesen.
I may be backwards on this but I believe it's supposed to bring higher rpm and less torque. The goal is for them to close at the right time to allow exactly what the engine wants.I'm new to the reed valves. What would the softer reed do? I know my stock one was thin metal.
