- 12:51 AM
- Dec 31, 2015
- East Jordan, MI
God I miss those days. Real cartoonsI saw one like it on an old "Roadrunner" cartoon!! The coyote didn't fare too well.
That was for doing saw blades in a sharpening shop from 8" to 30" you could at the time also get attachments for saw chin and bansaw blades if you can find themAnyone ever seen one of these before? It's for sale local.
I cured it by installing a switch to reverse the direction my 511 spins. No more lifted chrome with the wheel spinning into the cutters from the outsideBought the Kool-Aid, but . . .
I have been sharpening with a chain grinder for a number of years. Learned a lot of things; still open to learning more, Got pretty comfortable using conventional ('vitrified') aluminum oxide (AO) wheels, and with 'resinoid' wheels. But read many enthusiastic posts about CBN wheels, so finally broke down and bought a set of 1/8" and 3/16" wheels for my Oregon 511A grinder from Diamond Wheel, Inc. Used them on a few loops, and to twist a quote from 'Thelma & Louise', still haven't found out 'what all the shouting is about'.
Used them side-by-side with 'pink', 'brown', and resinoid wheels on similar chains, switching back-and-forth between loops. They definitely produce less dust than conventional wheels, and don't produce the smell that resinoid wheels give off. But they were not any faster, and the finish was not any better IMO.
Specifically, I am having a problem where they are more likely to raise the chrome plating right at the edge. I can dress the AO wheels if they do this, but not sure what to do with these CBN wheels. Is there a 'break-in' period? Do I need to dress them with that white stick when new? I have a call in to the sales office, but would be interested to hear from others if they have or have 'solved' this problem.
Philbert
Just hooked up to a compressor?I cured that by adding my air cooler . . .
I use just enough to cool the cutter, its a real small amount, dont even feel a breezeJust hooked up to a compressor?
Does not blow dust towards you?
Philbert
Nice. Good idea. Wonder if a air sample pump will put out enough air to cool the cutter. I think they will do 10 liters a minute with 1/4 od line. Without the noise of the air compressor. I have a few sitting in the shop.I cured that by adding my air cooler
I've switched over to the Loc-Line flexible stuff since these pictures.
View attachment 94808 View attachment 94809
Hey @Philbert been so busy I haven’t been on forums for a while!!!
I do sometimes get the “burr”, I was all worked up about it at first, but after lots of cutting I don’t worry about it now...
I prefer the resinoid wheels for hogging off really rocked cutter edges.When you guys get flat out trashed out dull Chains do you use the CBN or the stone wheel ....when my CBN wheels were new I of course used the stone wheels on the horribly dull Chains and the CBN on the better ones and my Chains lol....
But you can without a doubt still burn a chain with a CBN wheel if you take a big bite....
Have you ever “worn” out a CBN wheel, or donyou just have different brands...I think the new cbn wheels are more aggressive. My newest wheel gets the cutters to hot. My other three wheels didn't. Same part number. The kool aid was great. New batch. I have tried my new wheel on different grinders with the same results.
