Philbert
Chainsaw Enthusiast
- 5:38 AM
- Jan 30, 2016
- East Dakota
Wait! What place does common sense have here?
Philbert
Philbert
Youre learning things that probably wouldnt be able to register without you trying these different things !Yes you guys are excactly right....experimenting I have found out that to much hook is hard on, the chain and the saw....it can be to way to grabby as you guys have said....
If you look closely at Oregon or Stihl chain that is brand new, it has an aggressive top plate face....however,they have the side plate to support it.... basically if you have to much beak, it won't be a good work chain LOL...
Could not agree more, Thanks man....ya I have learned that just becaus a chain "looks" good, doesn't mean anything!!Youre learning things that probably wouldnt be able to register without you trying these different things !
This is why I believe that you have to try things on your own, so you can change things on your own, so you can see what works best for you !!
Wow, very nice!!!@Khntr85 keeps asking for photos. Here is a damaged full chisel chain, where I had to take the cutters back pretty far to get back to clean metal on the top and side plates:
'Before'
'After'
Single pass with a resinoid wheel.
Philbert
It kills me to take all the material off these damaged chains, but we have no choice /QUOTE]
Either that, or welding it back on!
This is one company that makes replaceable chain inserts for harvester chain - the idea is quite old, and there are some patents going back a lot of years:
http://chain-serts.com/
Philbert
You have me wanting one now.
What angle do you set the wheel at ?@Khntr85 keeps asking for photos. Here is a damaged full chisel chain, where I had to take the cutters back pretty far to get back to clean metal on the top and side plates:
'Before'
'After'
Philbert
This wheel is 10 or more years old, I got it with the usg I bought recently...You have me wanting one now.
Do you make any commission?
My 'standard' (unless someone asks for something different) grinding angles are 30/55/0What angle do you set the wheel at ?
