Big bore and stroked Husky 395 build.
srcarr52
5:07 AM
Iowa City
I'll buy you one for machining my crank. :D
I already bought a Walbro WJ-71. I've had good luck with these carbs and they are cheap. I'll just need to add an external impulse, and thanks to Dave I have plenty of impulse barbs.
But seriously, if you want a crank machined we'll work something out.
Lightning Performance
5:07 AM
East of Philly
Do you think the stock t760 carb would be a good one to try?
For whatever reason...I find the earlier tillotson runs real good on these and the 385/390. Nothing wrong with the walbro, I just think the tilly just runs well.
What carb is that?
I have a TS760 Tilly carb.
srcarr52
5:07 AM
Iowa City
Machining the weights is much simpler . For the rod just buff it till it clears , I've been putting those 2100 in 394 and jonsered 2095 for years to turn them into 6 cube racers and its been holding fine ;) What did you do for the key ?
I cut the keyway in by hand. I was only 5 deg off from where I wanted to be when I check it with a timing light. Then I just filed the cast in key in the flywheel to get it where I wanted.
5:07 AM
He's a hand model.
Not much sausage there.....
5:07 AM
Hey Shaun when you mount a 394 carb to a 395 how do you do it? The venturi is about 1 mm larger on 394 carbs I think. I tried to at one point, but the throttle shaft interfered with the throttle cable holder and I gave up and put the 298 tilly back on.
cgraham1
2:07 AM
Nor Cal
Can you put one in a 288xp? I think the 394xp uses the same crank as a 288xp...
Now we're thinking!
My saw runs good, but a couple more mm of stroke and a few extra cc couldn’t hurt, right?
Just need a 2100 crank (turned down) and a 2mm spacer under the jug?
srcarr52
5:07 AM
Iowa City
They are basically the same carb minus the external impulse barb and the choke linkage hole is larger for the plastic choke pull instead of the steel wire.
I think the Venturi is about the same. They have the same throttle bore.
srcarr52
5:07 AM
Iowa City
It's more than 2mm. It's 1mm to make up for the stroke difference but then you have the difference in rod length. I used a 0.090" spacer but I took some out of the squish.
cgraham1
2:07 AM
Nor Cal
Oh, I see. I didn’t think that one all the way through.
mgr1
11:07 AM
Belgium
I'm a mechanical engineer and I do software programming. I was an automotive machinist before college. These are my personal machines setup at a friends race shop.
Where are you in Belgium? I lived in Leuven for a few months about 10 years ago.
Nice tools for playing.
I live in Lanaken, 5 miles from Maastricht ;) and 40miles from Leuven.
