HumBurner
- 3:00 AM
- Apr 19, 2022
- Humboldt
WowMy guess is that BS is being called because that’s not what you originally stated. You attempted to sway someone to your way of thinking that a saw used within its designed engineering parameters would wear out sooner because it was being used in a manner that you deemed “hard”. Who said he was using it “maxed out all the time”? Stihl recommends up to a 20” bar for the ms261. Which means they designed it to hold up long term to full bar use at that level.
When you got push back you said, essentially, “meh to each their own” which was a contradiction to your original cautionary statement. Now you’ve moved the goal post again with your last statement. Of course a bigger power head will get the job done faster but not everyone has a pile of saws laying around. Surely you can see the issue others are having?
I'm not trying to sway anyone. Cautioning and swaying them are very different.
I didn't say anything about speed of getting the work done, either.
I'll just keep my opinions to myself.
Enjoy!
