Nighthunter
- 4:35 PM
- Feb 18, 2018
- Tipperary Ireland
Are you gonna powder coat the cases Dan, looking good so far
I never really examined it when I bought it Dan, only a quick glance over it and put it away, only thing on the cases it that it was previously opened or so I thought
Do you do your own powder-coating Dan? I've had a lot of stuff done by Mike (Glock37) and his powder-coating is much tougher than factory coatings.
What you have there is a poly short case pto side mixed with a ms660 fly side.... good luck trying to get those to seal. Check out my thread crying the 066 blues. Case volumes between the 2 are different so gasket wont match good, then seal surface just infront of cylinder below muffler will have poor gasket support
And the part under were the base gasket sits on ex side, im not talking the cylinder base surface which i had problems with that also.Yea, the opening of the case is were i had issues too. Between the oil tank and the crank housing
Sand/bead blast?
Thanks DJ.Very nice Dan.
