Yeah, I have torn up my KHs pretty good...but they are comfy and don't shatter. I was dropping some fatties for a buddy and he broke a 12" Oregon. They ping noticeably when schwacked...but the heads don't mushroom much. I will try some blue wedges to go with my blue axe, I like Madsen's.As far wedges go we normally run the Madsen’s branded wedges they stack nice and they pound decent. The red heads are so so a little too soft for my liking especially in the big older fir you’ll destroy the heads quickly if you don’t have two in the back cut together. Another option if you’re having trouble keeping wedges together when stacking is the rifled wedges I don’t remember them spitting out and they can’t come a part well really beating on them. And if that’s bad it maybe time to pony up the money for a set of jacks yes they’re expensive but they’re worth every dime when you need them.
That ole pine knocked the spikes down.
The fiskars took chunks out if my strike was off, the sledge mushroomed them a bit.
I agree with the hard head modification.
You need to narrow the wedges strike area, that way it won't mushroom wider than the wedge is thick & wide, and any mushrooming can easily be knocked down.
I would suggest practicing making your own wedges out of the same tree you’re cutting on site. For situations like you just described it’s the perfect solution.Of course last Saturday I was felling a bunch of squishy wet ficus and didn’t have my stippled aluminum wedges. Only thing that would stay in those trees was a single long thin wedge sideways. I tried dirt, sawdust, everything just squirted out. Ended up chasing my cuts so one wedge was sufficient.
Same wood sticks to same wood? Or that type of wood would be good for wedges?I would suggest practicing making your own wedges out of the same tree you’re cutting on site. For situations like you just described it’s the perfect solution.
I mean any wood could do. You would ideally use wood from the same tree if you could. I usually have tons of branches to cut wedges from by the time I fell the spar but have made wedges out of the face cut. No right or wrong way to do it really. A little practice and you’ll figure out what works best for you bud.Same wood sticks to same wood? Or that type of wood would be good for wedges?
