PA Dan
- 1:12 AM
- Dec 28, 2015
- White Oak PA
Husky guys...[emoji23][emoji1787][emoji28]So you find a flexing bicep sexier than a low-cut top?
This made me raff out roud!So you find a flexing bicep sexier than a low-cut top?
You’re really stretching out for that oneHigh tops are prone to breaking easier also
How would you know? You don’t have anyThere TOP heavy.LMAO
I considered 394 as one of the 2 series saw After all it has 2 series style oil pump, intake. Even the crank is the same as the glorious 288.Same could be said for all 2 series saws and the 394. Imo
I guess so. I can see a little of the piston crown at bdc on mine. But ir runs fine. I use it to make big cookiesI know you need to measure but does a 288 typically need a base gasket
Agreed. The only thing a kin to 3-Series on the 394 is the plastic removable carb box floor. Everything else is good old 2-series.I considered 394 as one of the 2 series saw After all it has 2 series style oil pump, intake. Even the crank is the same as the glorious 288.
Hows bout a poulan wild thang thread?I will say this, 103 pages about ONE model speaks for its following and the people passionate about it. I'd like more threads like this about other brands and models.
