- 12:58 AM
- Aug 6, 2016
- Tennessee
I got a mint 288 not made in Brazil if someone has the cash.
Fit ain’t a high top with a full wrap hit will probably be a tuff sale
Yeah that's ok, it's PD for, just throwing it out there as an offer.
I cut that flap out of mine and installed the deflector facing forward. It’s louder so it must have more power...lol!
Nice looking 288 Tony.
I haven’t tested that. I wonder if a big hole under that giant deflector would gain???? Next time I’m goofing around with my 288 I’m going to try that with a spare muffler I have sitting in a box.Yeah the flap will go, no question there.
New higher flow screen.
Has anyone ever tested the difference in cut speed with the deflector facing in, and out?
I haven't done the reverse vs forward cover specifically with a 288, but with the dozens of muff mods I have done, I've noticed the closer the opening is to the exhaust port, usually the more effective it is. Prolly sumfin to do with exhaust impulse and velocity on a non-tuned 2 stroke exhaust. Loud, tho.
Yeah I’m not such a fan of low restriction openings right at the front of the muffler.
I prefer openings back closer to the cylinder which flow well to drain pressure over tbe entire cycle but provide better backpressure as the transfers open to help loop scavenging and prevent short circuiting of transfer flow to the muffler
That looks like it should work!
I would give it more intake as well. Did you raise your exhaust?So I got a little spurt of ambition tonight and put the piston in my 288 to check some numbers. With no base gasket I only have .015" squish, so I will have to use a thin gasket of some sort. As it sits with no gasket, my timing number are:
100 exhaust
126 transfers
73 intake
I'm thinking of taking a little off the piston skirt to get a little more intake duration. What would you guys do?
100 exhaust
126 transfers
73 intake
I haven't touched anything yet. Once I get a thin gasket cut I will recheck my numbers and go from there. I am not going to do a lot of grinding on this cylinder as it's my only 288 and likely I will never get another one. Having said that, per your and srcarr's advice, I am leaning towards raising the transfers a bit, smoothing and port matching the intake, and trimming the piston skirt to get a little better performance. I have already modded the muffler and I have a bigger carb here that I can install as well.I would give it more intake as well. Did you raise your exhaust?
