Used dent pullers from Jason and Dallas?
No gaskets.Going back together, slowly as I still have some parts on the way.
Ready to bolt the carb housing back on.
Don't forget the impulse...
Then fish the manifold through the plate.
There's a small rubber seal in the bottom right corner that seal the duct to the bottom of the housing.
Now, my ipl is for a non m-tron saw, but it appears there's an aluminum plate with a duct that goes over the top carburetor studs ( called a preheater plate in the ipl) and just a ring around the outside of the strato studs.
I have these ordered.
It also appears the carb just bolts right up to these, no gaskets.. could you guys who've been in unmolested 441's verify this please? @Mastermind or @huskihl
No gaskets.
the aluminum piece is a bit hinky. It points to the upper right and a rubber sleeve/boot goes over both the black plastic and aluminum pieces
I can’t remember what the piece looks like exactly but yeah.Awesome. Thanks Kevin.
I have both the plate and the boot/or duct on order.
I'm kind of impressed this saw ran without it in place with no ill effects...there probably had to be a gap between the carb and intake or strato valve somewhere because the outer strato ring was in place..
Yeah that bîtch. You’ll learn to hate that before it’s overIt's one piece. The fuel and impulse line sit in a groove in the side. Both intake boots pull through, selector lever snaps in across the bottom.
I thought I had a pic of it separate from the housing, but I dont..
Edit. Found a pic off ebay.
Mine was missing the aluminum plate and boot at the top of it, otherwise looks like this
You mf'ers are just going to have to wait.
Or you could always get a job at USPS and expedite the shipping on those parts for me.
Puts me at a stand still. Can't put the recoil on because I need to access the throttle cable through there.
Can't put the carb on because, well, the aforementioned part goes on before it.
