- 11:31 PM
- Dec 31, 2015
- East Jordan, MI
It fits. Almost the same diameter as the drumId like to see it fit, lol
well put.Skip is always slower on shorter bars. It’s easier to sharpen by 2/3, but the chain also goes dull exactly that much quicker. Unless you’re attracted to hitting rocks, in which that case skip would be better.
If you’re just bucking/down cutting, an 8 is faster on bigger saws or shorter bars. If you need torque and forgiveness to get through pinch/compression situations, a 7 is better
I have a 10 and 12. Tail of the bar is cut off to match the height. Common in competition.Id like to see it fit, lol
another part of the equation could be if using a 28" b&c cutting 28"+ wood or cutting 10-20" wood but wanting to stand up and buckIt comes down to the wood species You are processing and how You are cutting, bucking or noodling.
90% of what I cut is bucking Turkey oak logs, that stuff is dense and won't compress.
As such I see gains utilizing:
- 1.) a 7 pin instead of 8-9 pin, the chain just bites better and gold a more steady bite throughout the bucking cut
- 2.) full skip on 24"+ , less bog down due to chip clearance issues
Softer wood species like beech, hornbeam, cherry, walnut - go crazy, 8 pin full comp!
That stuff is "speedwood" in my book.
Yeah, I don't understand the latter.another part of the equation could be if using a 28" b&c cutting 28"+ wood or cutting 10-20" wood but wanting to stand up and buck
I get it. I have a friend my age with a really bad back and is already on his second hips. He just can't bend over easily or comfortably or get work done over a few days if he's bending to cut/buck. He always runs a 28".Yeah, I don't understand the latter.
Like, at all !!!
I can't and won't utilize a B&C setup longer than the wood OD requires just for the sake of "not having to bend down"!
No chance.
I'd rather over buck with a shorter bar than do that!
But, hey - whatever works best for each individual.
I ain't gonna judge.
From a reasonable aspect, with his health issues he shouldn't be doing it at all!I get it. I have a friend my age with a really bad back and is already on his second hips. He just can't bend over easily or comfortably or get work done over a few days if he's bending to cut/buck. He always runs a 28".
But he doesn't cut for a living.
Like, at all !!!
No chance.
Your bar might cry enough is enough....Now if you put a 12 pin on a 3120…
Something people don't seem to consider going berserk on drive sprocket size!Your bar might cry enough is enough....
Thanks for posting this! I was thinking of doing the same test and I figured someone else already had I just hadn’t seen it!I would definitely go 7 full
Here is a video from Julian:
Of course skip isn’t as smooth as full especially when boring but if you put a little twist pressure on the handlebar it pretty much eliminates the jumping.I have no experience with skip chain, does it bore cut well? I always thought it’d be jumpy
But in 28”+ wood I run a 7pin full
if you’re using a 28” bar to work up some small wood then 8 pin
I haven't experimented with swapping sprocket sizes yet but I've always been interested in the outcomes. It all comes down to intention, like many things in saws and life. Small saws generally have higher chain speed as is and aren't really designed for firewood duty. Big saws are slower with greater torque.Thanks for all the input! Believe I’ve decided on 7-pin for the forgiveness and better for the saw standpoint. And also the fact that the chain will be running on the bar at a faster speed and the oil pump still pumping the same rate with the 8-pin.
DON'T Let the TRUTH get in the way of a GOOD STORY...Better try it again to be sure.
