WI_Hedgehog
- 9:29 AM
- Sep 8, 2023
- Milwaukee, Wisconsin, U.S.A.
Wrong, IMHO!@Wilhelm : Since you're a speed guy, what's faster in clean wood with a big powerhead (90cc and up), 3/8" or .404"? I'm hearing .404 if there's enough power to pull it even though it has wider kerf.
Almost there, once past the witness mark that chain becomes a light sabre - although prone to pinching.
She’s a little rough lol, cuts goodAlmost there, once past the witness mark that chain becomes a light sabre - although prone to pinching.
Those DL's look f-ed up!
Even some chipping on both, what happened?
Raker looks too high, would make a in cut low bite high chain speed loop.
Nice big-C profile!
I made a post a year or two ago about using .404 as brushing chain, but wanting a smaller powerhead still. The suggestions were the earlier Stihls, which also generally happen to be a pain working on from what I read.Wrong, IMHO!
You want half-life 3/8" full chisel!
It is super fast and doesn't pinch.
Talking hardwood, turkey oak in my case.
It is lightning fast in fresh beech.
.404" is a power hog, cutting a too wide kerf and fewer teeth.
Round ground/filed in any scenario!
From what I gather out of this forum many favor .404" for its extended "stay sharp" properties.
I will rather swap out 2-3 saws than pretend a chain is still cutting at the expense of wear & tear of the PH.
I don't swap chains!
P.S./Edit:
Keep in mind that for now 90cc is the largest I own/run!
Runs smooth, without being over aggressive, a smooth chain is a fast chain,Looks durable from the outside!
At the risk of wearing it quicker, I'd be tempted to take the depths down a swipe or two from where you have it.
Did you get a 661 Brad?MS 400 & MS 661.
In dirty, snotty wood (storm damage) full-chisel can dull in 3/4 of one cut, semi-chisel can last 20+ cuts, I've had it last about 40. I'll be getting chipper chain to run on a hard nose bar next week. Yes, it's slow, until you don't have to stop to change out / sharpen chains.
In clean wood speed is the king.
I have some RM, tried it and wasn't impressed - stashed it back in the box and onto the shelf.@Wilhelm have you tried stihl RM? I like it.
I can tell you the .404 stihl SC chain works for me. I have RCA base in my cutting area, so it’s quite abrasive. I set my rakers kinda low.I just can't get a liking for semi chisel in any pitch!
Does it work?
Yeah???!!!
Is it satisfactory fast cutting?
Heck no!!!
To me semi chisel is so underwhelming in performance I have sort of an hatred towards it.
Maybe I don't know how to sharpen it?!
Yea David , the factory square grind on Stihl is a blunter angle and temper of cutters is harder than the others , should hold up decent in tougher wood , I rather use .404 in less than ideal wood conditions, as long as you have the PH to pull it ,@Wilhelm have you tried stihl RM? I like it.
I agree I expect 3/8” to be faster - in clean. In nasties .404 rules.
Thank you for the 3/8 / .404 chain info. Do you mean past the minimum tooth size indicator?Almost there, once past the witness mark that chain becomes a light sabre - although prone to pinching.
I did not, @julie wolf offered for me to borrow her MS 400 whenever I want, and that's great power for the weight. I was thinking of getting a ported MS 462 because I like hers so much but we put that on the back burner for now. I really like how light her saw is.Did you get a 661 Brad?
I need a woman I can borrow a chainsaw from in my life!Thank you for the 3/8 / .404 chain info. Do you mean past the minimum tooth size indicator?
Yesterday after cutting table tops I put STIHL 3/8" full chisel full house into two pinched dirty windfalls to help the trees they were pinched by healthy--it's still sharp. That saw is like having a gym membership.
I set rakers every half dozen sharpenings or so, no need to set rakes every touch up or thorough sharpening!Most of what I do is with one saw. I’ve found full skip with the rakers waaaaaaay down works for brushing and limbing really well, and that’s mostly what I do at work, and it’s fine for bucking. I really like the low rakers for felling, just drive a little harder on the spikes and it stops when your gun is set. Another bonus is with the rakers far down you can just put a lick on the chain when it starts getting dull and you don’t have to take the time to get the rakers as well, just another swipe or two off after the day is done and you’re ready for the next day. I always have a brand new chain in my pack too if I really mess it up with how many rocks are around where we cut
