KiwiBro (deleted)
- 5:37 AM
- Feb 19, 2016
- New Zealand
No idea sorry
Only by opening up the stud slot to 12mm.Those both look pretty tempting. I'm not that stoked on a hard nose bar, but for $15, it wouldn't the end of the world to try one. Would either fit a mid sized stihl mount?
Easy enough to do with a small angle grinder.
I bought one of the .404 20" GB CN 40 bars a few weeks ago. It's one of the Stihl mid mount bars. I lengthened the slot on it so I can run an adaptor on my 395 with an 8 pin. My thinking is, it would be fun blocking firewood next to someone running a 460 Rancher, or MS 311......LOL!
They still showed 20 or so, in stock, when I purchased mine.Any leads on another one? Or did you get left coast's last one?
.404 will oil a lot better than 3/8 milling ,at least for me it doesI wouldn't run .404 milling at all. Puts a lot more load on a saw.
Milling is tough on a saw. Until I tried it myself, I couldn't believe how slow it goes and how long it takes.
My MMSW066 pulls a 36" 3/8 8pin through hardwood (cutting-not milling) with supreme authority. Slap a 28" .404 7pin (same size as an 8 pin 3/8) and I need to take my time or the saw will bog out easily.
Seems to last longer than 3/8 though. I wacked up a 36" by 70' hard maple with 404 with only one sharpening. That was cutting and noodling the rounds in half. Don't think 3/8 coulda done that.
Looking through there website I found this. Stihl mount 25" 404.Another bar deal I thought was pretty blardy good was this one:
http://www.pressureparts.com/075-294
I file semi chisel pretty slow for that affect
That's bout what I do with semi chisel seems to last real wellFor dirty wood the top of your cutter should be like this ,almost strait across ,this is referred to as slowing the chain down ,ends up in a stronger outer corner and will stay sharp longer .
The lh skinny cutter chain is a semi chisel ripping chain for milling ,the rh one is rsc .404 sharpened to 10 -0-40 on the usg mcan see how much wider .404 is ,rslf .404 is even wider on the cutters .That's bout what I do with semi chisel seems to last real well
I see. I've never ran 404 at all just 3/8 and 325 I usually avoid dirty wood as most of what I cut is green woodThe lh skinny cutter chain is a semi chisel ripping chain for milling ,the rh one is rsc .404 sharpened to 10 -0-40 on the usg mcan see how much wider .404 is ,rslf .404 is even wider on the cutters .
In softwoods like cedar or fir i get a pretty nice finish with .404 chisel chain as long as i do not push too hard and let it eat as it wants .the .404 oils the bar better but there is more sawdust waste due to the wider cutters .Looks similar to a bandsaw if not smoother .How do these fare when cross cutting compared to regular semi chisel? I still need to try those angles you mentioned yesterday, think it was 20-20-40
