Vintage Engine Repairs
- 12:44 AM
- Aug 15, 2019
- australia
Thanks for bringing us along Al, I can’t wait to catch the first start!
use a tapered 880 pin and grind it to length.Thanks for the reply. Wanted to try one for myself.
I’ve heard it’s a lot of work for not much more gain. I’m only at 65% bore width on the exhaust, which is where many take their builds without a lot of short circuiting. In addition, I’m right on the edge of the stock piston‘s skirt, I probably coulda gotten away with it, especially with a the winged skirt type slug.
I didnt do fingers, hard to make them not just push the flow circuit back towards the exhaust. I am making sure to have at least 40-45* of case compression and to keep the transfers as tight as possible to prevent short circuiting. In addition, opening the transfers at the ex side first gives them a better chance to push charge away from the exhaust.
The piston is already lighter than an 066 one. And it’s gonna lose even more weight when I clean up the casting flash and add a 395 pin.
As for the exhaust, I always do rearward placed side exhausts. Front openings don’t allow the sounds waves to collide and cancel each other out. It’s just loud without a lot of gain.
Guess I’ll see if the lemon was worth the squeeze.
Ain’t got one. Piston and pin are currently lighter than the stock OEM 660 piston and pin. I may bore out the meteor pin. It’s super thick.use a tapered 880 pin and grind it to length.
The husky pins are thicker and heavier
You did the powder. Excellent work, as always.Great work Al
cases look great should be awesome when done
