NPKenny
- 7:31 AM
- Jan 12, 2018
- Lehi, AZ
First time for everything….
Saw is a bubble top Stihl MS660 with a meteor piston.
I’m a conservative porter and have never missed on a port. Figured I would rough in the exhaust after getting the transfers where I wanted them. I got everything cleaned back up, dropped the cylinder to find that I had overground the width by a lot on my exhaust port and exposed past the skirt. It’s a scalloped skirt piston and I was careless.
1. What is the risk of running like this? Lots of discussion on freeporting the bottom? But not on the skirts.
2. Rotating the piston does not cover the port.
3. There aren’t obvious piston choices to correct this. Husqvarna 288 and 385 are discussed, but require a bit of work to match the 12mm con rod and 13mm piston.
Any recommendations?
