flyin'chips
Active OPE Member
- 11:25 AM
- Jul 29, 2020
- Between piston and cylinder
Played with tuning. Went all the way from rich bog to lean bog on L (1 1/4 - 3/4) and the idle behavior after wot is the same, down it goes to 2000-2300 to return to 2700 (or whatever it's adjusted to +- 150). The rpms, throttle response and power all react logically and well to all adjustments. So it's not the tuning.
Without the bar and chain and the idle behavior after wot is the same. So it's not the clutch.
Let it idle for some time and turned it upside down on two different tunes and all possible orientations. Upside down the idle goes a bit higher maybe but certainly does not slow down or stop. Thus the crank case does not get flooded. Otherwise the orientation has no effect on idle speed.
Pressure tested through the impulse hole in the cylinder to verify that the spark plug thread doesn't leak (before had the tester in plug hole) - no bubbles.
Pressure tested the carb through the fuel intake and press/vac the impulse hole, holds.
Checked for resistance in the fuel filter (I've had defective oem filters before) and fuel line, fuel flows nicely and easily.
Checked the intake boot again and aligned the gaskets, the boot and the carb according to the marks left on the gaskets and I can't see any retrictions in the impulse passage. All the intake holes grow larger when going from the carb towards the cylinder - no restrictions or lips allthough someone could probably enhance the flow dynamics inside the intake by chamfering all edges. I will enlarge the impulse holes in the gaskets a bit and chamfer the carb impulse hole like suggested.
Today I noted and it's probably been like this all the time that the saw was actually difficult to start when cold. 5-6 pulls on choke, then 3-5 without and died immediately. After many pulls later started on high idle but died when blipping the throttle. Then started on choke and high idle and stayed running. So it doesn't sound like it's flooding at least when cold.
The saw has a very rough sound on idle especially when the idle speed is 2500 or lower. Hard to explain but a bit like there was something hitting or playing another rough rhytm inside. Very far from the smooth idle sounds of 55 or ms261.
Thus I think this is most likely about ignition or about the worn piston skirt.
If the coil was bad, could the saw run well on WOT but not idle properly? I know nothing about ignition.
Anyway I will purchase a new used flywheel with a key and if that doesn't fix it then order a new piston.
Thanks a lot for all the shared experiences and suggestions!
