10 mm 044 ish
Red97
11:56 AM
MI
Plan as of now,
.010-20 ish off base, just enough to set squish/clean up the band.
Not sure where the numbers are, but don't plan on straying too far from them just a bit of clean up etc.
Open up the muffler, got a dual port cover for it as well.
I'll order a oem boot/10mm piston/bearing as well.
Curious to see how well a big squeal runs..
Canadian farm boy
“Normal” people scare me.
11:56 AM
Ontario, Canada
Plan as of now,
Sounds like a real solid plan Joe. I don't think you can lose.
What condition is the carb in? I'm kinda thinking that after all that work and all those new parts maybe put a carb kit in it just to be safe.
Red97
11:56 AM
MI
Sorry, figured That was a given.
This one has a zama? That a stock option? Any better alternative? ?
Canadian farm boy
11:56 AM
Ontario, Canada
My 044 hybrid is running a Zama c3m.
IIRC the walbro carb was a HD-16
Personally I've only ever seen these carbs on a 044. I'm not sure if there was other options
Canadian farm boy
11:56 AM
Ontario, Canada
The walbro HD-17 from a 046 is a direct fit. I don't know for sure if it would be a better option or not
Red97
11:56 AM
MI
Has
12 88 1A
cast on the side if that means anything important.
11:56 AM
What are you wondering? That is one of the early KS 10mm jugs. They went up to 5 or 6 + signs as they made minor changes through its production
Red97
11:56 AM
MI
I guess if this was one of the better jugs? Not that it really matters.
Thought I heard the KS jugs were more desirable for some reason.
11:56 AM
Yes. The earlier the better is my understanding. One + sign is early. She'll run just fine. Prolly cut circles around a measly 372:tiburon:
Red97
11:56 AM
MI
I had a 371 once...
Chainsaw Jim
Con Artist LLC
8:56 AM
Springfield Oregon
I just compared a one plus ks to a six plus mahle and they are both dead on with the exhaust and transfer timing. The mahle is one degree higher at the intake floor. The ks is one millimeter wider at the exhaust. the ks has more bevel at the transfer where the mahle has more bevel at the exhaust.
Red97
11:56 AM
MI
41.50 for a oe 10mm piston kit.
After the fella tried handing me a lrb am piston. I politely asked him to Chek the part nuber I handed him, pretty sure it is still a valid part.
What ya know it was. With prices like that why even bother with aftermarket??
Deets066
AKA Deetsey
11:56 AM
My hybrid has the HD 17 B, it came from stihl on the new tank/handle I got. Which is from a 440. My 046 has a HD 17 A. What's the difference?
New EPA regs ?
Stihlbro
11:56 AM
Virginia
10 or 12 mm crank(12mm case damaged/10mm case leaks at bearing pocket.
Cover with "character"
O46/460 cylinder to mock up a hybrid. Chamber and base cut on the one on the left. Some one else polished the intake and exhaust.
Will these work?
Red97
11:56 AM
MI
Yes sir that will work just fine. :)
