Adirondackstihl
- 11:41 AM
- Dec 4, 2015
- Upstate NY
Both sets of clips mic out exactly the same.I've used the Meteor pins but with OEM circlips .I had an awful time trying to get those fat azzed Meteor clips in place .
Other than the blueing, it’s as smooth as glassIf it's smooth and there's no spots that can catch a nail, then I'd re-use it. I've found a lot of the time that the used OEM wrist pin is a better fit in a new Meteor piston than the new Meteor wrist pin is.
Dimensionally , The OEM matches the meteor almost near exact so hopefully I’m goodI always reuse OEM pins Jer.
I've got a bunch of new-in-package Meteor 026 pins around my shop.
Some aren't the same size as OEM. The 046 Meteor pin is longer and heavier than the OEM, so I stay with the matched pin on that saw.
IIRC, they were within 0.01mmJust be sure the oem pin ain't longer.
I chuck them in a drill and shorten them with a bench grinder.
Nah Broseph,Dimensionally , The OEM matches the meteor almost near exact so hopefully I’m good
Not on an 046/460. At least not on the one I had in my hand. I wanted to reuse the OEM pin, but they were different lengths.
Owe, eye sea...I chuck them in a drill and shorten them with a bench grinder.
Sure is.Is 1122 034 1500 not available to order?
