working on other builders saws
tree monkey
12:05 AM
wi
at this point all forward progress has to stop. I can fix this with epoxy. but it is up to the saw owner as to what he wants to do.
epoxy fix, port a new cylinder, or send the whole thing back to the other porter.
tree monkey
12:05 AM
wi
tree monkey
12:05 AM
wi
it's about the same all around
danimal
12:05 AM
Armpit of da Midwest
I talked to the saw owner about what he used for oil, ratio, fuel. how he liked the saw when it ran, things like that.
stihl white bottle, 50;1. he liked the saw but it never idled right. said it only lasted about 50 hrs.
I don't think he retuned it when he got. my first thought was bad tune or air leak and it's lean scored.
Ya cant fix stupid!
danimal
12:05 AM
My biggest fear........
Most peeps dont know how,,,, lean mix , lean scream!
They have no bussiness running a hotrodded saw.
You and Scott kno a 100 times more than I do, butt I kno to run rich wiff gud erl and I run fat wiff clean air filters.. Thats 50 times more knowledge than the average joe...
I have one thing to say to most unknowing peeps who own or run saws. . .:ciappa:
danimal
12:05 AM
Some people think 50 hours.....and it's really more like 5.
If I have logs laid out to buck, and I run either of my 288's fer 5 hrs,
I have 15 cords of wood to split.
Bucked wif my hotrodded 288 sun for 12 min. ended up w/2 p/u truck loads of 20" locust..
smokey7
1:05 AM
Detroit
I just looked at the pics and all I saw was a pic of the intake port where it looks like the wear lines are inside the intake port window. As in ported too wide for skirt coverage.
P.M.P.
Stiff Member
1:05 AM
Michigan
I have a 357 that I done went crazy on the intake side I need need to pull jug to even the intake with epoxy.Just glad I realized before the piston is smoked.
thomas1
┌∩┐(◣_◢)┌∩┐
1:05 AM
Cristobal Colon
Unless your a logger it would take many many years for your average wood hack to put 50 hours on a saw.
I was always under the impression that it took a lot longer to cut a tree into 40 18" pieces than it did to cut it into 3 20' pieces. Maybe I'm doing something wrong?
GCJenks204
"Special Buns"
12:05 AM
Winnipeg, MB
And this gentlemen is why I want an all M-tronic or Auto Tune stable. I don't want to firetruck up someone else's awesome work.
jmssaws
Banneded
12:05 AM
Most firewood cutters don't cut firewood all day most everyday,a pickup truck load can be cut on a tank or 2 of gas but most loggers here burn a couple gallons everyday.
Yes cutting one tree into firewood takes a little longer than falling and topping one.
If a logger gets 2 years out of a pro 90cc saw then most wood cutters should get a lifetime out of it.
Termitebuffet
Home of the corn can muffler .....
1:05 AM
Midgetville Norf Kacolacky
There you go ...trying to math again.....[emoji2]
Zoo City Sawz
