working on an 026 need longer carb studs
Jughead
7:08 AM
Ebay search for moby scooter air filter.;)
So far the drawbacks are that the pockets for the hold down nuts arentwide enough to accept a 8mm socket or t handle to tighten them down.the pockets need to be widened out to at least 11.65mm for my wiha t handle to work.
Still trying to find an angled boot k&n to help clear the handle/trigger etc.
If anyone else gets to finish this before i do post up the results you find.
Jughead
7:08 AM
i ran one of these setups on my tanaka weedeater over the summer.so far so good.i still need to lap the rear base plate a tad to tighten up the choke.still not a bad fit for chinese craftsmanship.still cheap enough to modify to fit.
Jughead
7:08 AM
Nice there Brewz.i'm kinda limited to a battery powered drill right now though.my uncle does have a chinese drill press but its wobblier than i am on a 12 pack.
Stihlbro
7:08 AM
Virginia
Thoughts here, 028 style air filter/cover nuts may fit to secure velocity stack. Same thread.
Jughead
7:08 AM
I'll check that out seems i have many of those junked out without flocking.
Stihlbro
7:08 AM
Virginia
Where did you get the velocity stack from?
stihl_head1982
Here long time
7:08 AM
USA
now that idea is plum skeery...:yikes:
Jughead
7:08 AM
Be careful about that exact one if you go that route. 3/4" id. I think you're closer to 2" od on your stack. 1.5" maybe.
1 3/4" to be exact.i must have misread the description.
