Woods ported my 660.
Absolution
3:03 PM
WV/NC
Pictures of cylinder after 4 tanks @ 12,500/12,700. One and half tank milling. Seems to have a good amount of oil. There are what I would consider wear marks on piston (excluding the marks on top, I did that) there is no indention into metal only what seems like polishing.
Absolution
3:03 PM
WV/NC
Was the rod blued like that when you put it together? I’d be checking that big end bearing very closely...
I was originally worried but I looked uo and saw where peoole had those colors when they received them.
The blue on the rod is about heat. A couple of reasons why..I've seen that twice before...:)
So are you saying the colors are not normal? If it heated up while running I'm worried that it is starting to anneal and could cause a failure.
Absolution
3:03 PM
WV/NC
I like 20 or so in a 66. Mine has 17.
His saw seemed to run pretty good as it was though.
I like that intake, and I think your #s are good. Not sure if I would move the upper or not, 25* of blow down is just fine.
They all have that some just show up more extreme than others even my 064 show's color mid way down the rod.
How would I reduce the spit back? I would like to keep that oil in case as much as possible.
MG porting
12:03 PM
Wa
Well as I see it you port timing is pretty good it's ok to have spit back it's more less normal for a chainsaw. And yep I'm sure the argument will begin after my comment.lol
Deets066
AKA Deetsey
3:03 PM
Your losing case compression, but that should reduce spitback a little. You could freeport the exhaust a touch or fill the intake to 78 or so and that may reduce it a little. You could also lean it out a touch. Should be at least over 13,000
