- 1:58 PM
- Jan 8, 2016
- Kentucky
Nice work Kevin, I can't wait to see the finished product.
60cc. Sounds kinda much.
My homelite is 36cc. Screams with a muffler mod.
They have anything around 40cc. Any lightweight bars for them?
Nope. 60cc is small as they go.
You can get a nice lite battery powered ryobi from Homer Depot though
it said eat chit.
There are lots of pics in these build threads. It's shouldn't be difficult to put one together with all the pics. But yeah, I'd help somebody outThe 660 you did sounds and looks to run very good.
I mite look into the 036 kit, if anything be great to learn how to assemble it together.
Are you offering any help on how to put the kits together. And offering any advise?
One of mine was goofed up too. Only other studs I had were old school oem, not the extended ones. Too bad. I like thoseI installed 460 bar studs in my 066 (one was stripped, so I replaced them both). They are a bit longer and have better support for the bar. Just need to replace or mod the clutch cover holes, but I much prefer those bar studs.
You cant knock the value if you are ok with the spanners Kev. The muffler you get in the kit ? ...whats it full of "or not full of " as standard . I often use Farmertec mufflers for the 024,26,ms 260 and they are full of not much so just a little outflow work and there done.This is the 2nd best running $200 saw I own. I'm confident it'll get better after its ported. These are it's first cuts
I don't know, Randy. The only things that are visibly wrong were the casting and plating flaws in the jug. But that's fixable if a guy knows what it should look like.Question, is this a saw you would not be afraid to put in a tree services hands? Not one of the big companies but one with 10 employees.
I just did an oem 066 and this one about the same time. I can't remember if these are a hollow can or not. I can look tonightYou cant knock the value if you are ok with the spanners Kev. The muffler you get in the kit ? ...whats it full of "or not full of " as standard . I often use Farmertec mufflers for the 024,26,ms 260 and they are full of not much so just a little outflow work and there done.
Will you hold my hand?...............There are lots of pics in these build threads. It's shouldn't be difficult to put one together with all the pics. But yeah, I'd help somebody out
Just the crank is sir ,rest of saw all oem ,crank is not chinese though Raisman platt i think was brand ,italy or somewhere i think ? is where made .I believe someone said Brian was using an AM 660 for milling. If it stands up to that, it should easily stand up to tree work. The 660 was one of the most reliable workhorses ever produced, and those Cross MMWS kits make them run pretty good.
I didn't check it. I'm not worried if it Freeport a little. I've had a couple saws that had a half mm freeport and were really good runnersMine was hollow Kevin. I actually like the hollow muffler better. I gut the OE mufflers anymore anyhow.
Kevin, how much meat does your piston have at the bottom of the skirt at TDC? Without a gasket I've got .020 before Freeport. Handicaps me with machine work.
Sure. But can I at least call you Brieanne?Will you hold my hand?...............
LOL, you can call me anything you want there sweet cheeks.I didn't check it. I'm not worried if it Freeport a little. I've had a couple saws that had a half mm freeport and were really good runners
Sure. But can I at least call you Brianne?
Do I have to pay to see where this goesLOL, you can call me anything you want there sweet cheeks.
Yes. You have my paypalDo I have to pay to see where this goes
