Windowed piston in an open port cylinder ?
82f100swb
3:43 AM
Dryden, ON, Canada
Keep in mind, that while the 262 carb physically bolted on, I had to make my own throttle and choke linkage, as well as come up with a solution for the air filter. The stock components no linger fit, as the 262 carb is physically longer than the 55 carb.
When I say non Husky, I do not mean non OEM, I will be using a closed port top end from a Partner/Jonsered cousin on the next go-round.
5155
4:43 AM
pa
At one time I had a Sachs-Dolmar ??? that the top looked close.
It was used for cutting stone. The ones that were not cleaned religiously did not last very long. Operator thing.
I barked at the owner (good friend) that he needed to keep several filters on hand. He sold the saw and bout a JD, multiple filters, a water hose hook up and drove on for a long time.
Another friend hooked up a mini-bike gas tank as a water feed.
I laughed and said, brilliant.
Stone dust is tough on saw parts, and people...
Maintenance Chief
4:43 AM
South Carolina
I just put this 55 together this morning, 028 piston,and an open port cylinder. It runs pretty goid for what it is. Its gonna have to break in before I get a good idea of what it can do.
