Which One ?
Which one to have hopped up if you had to choose ?
  • Husqvarna 357xp
  • Dolkita 7900
  • Stihl 044 10mm (Artic version)
  • Husky 346xp
Results are only viewable after voting.
bryanr2
12:29 PM
USA
can't believe the 044 and 346 are ahead. he already has a 346 done and 365 done. do something different.
GCJenks204
"Special Buns"
11:29 AM
Winnipeg, MB
I went with the 7900. You have the mid range well covered already, why not go with the biggest one?
ft. churchill
9:29 AM
Along the '49 trail in Nevada
Do the smurf blue dolmar. It is the biggest you've got and you may want the power someday.
Besides, you got a ported 346, 357 run great stock, as does the creamsicle. Show us a ported Dolly later.
P.M.P.
Stiff Member
12:29 PM
Michigan
The 357 is out of the picture for now.I done had my fingers in it.
Frank bierce
9:29 AM
Oregon
357 gettin no love
This is what I would choose myself..but have never had the opportunity to run a 7900. A great high revvin mid sized saw...would honestly probably end up being my go to saw
Frank bierce
9:29 AM
Oregon
The 044 would be a great power to weight ratio, and an all around legend of a saw.
tickbitintn
11:29 AM
middle tn
This is another one of those trick poll things that doesn't have the correct answer available to select.....
the correct answer is...... ALL of them..... :campeon: :banana:
SixGun
12:29 PM
Hackettstown NJ
carry all day and run a 28 if necessary.
10mil's run strong
czar800
12:29 PM
Ellwood City
I'll some times never get the 026 out of the truck and use my 046 for all.
P.M.P.
Stiff Member
12:29 PM
Michigan
Sorry for misleading anyone.
I cant change the Title but I was wrong just wanted to clearify should have done it sooner.
The 044 is a early 12mm with the 10 mm jug.I believe has the heavier flywheel because of the heated handle like the earlier 10mm had from th reseach I did. I got a private message from another member here before posting this thread telling me about his that he had a angled finn 12mm with the heated handle.I assumed all the angle finns were 10mm.After talking to other member did some research to find ot where the # was located it was covered in grime.The serial # is 131915xxx .I got saw couple months back it came with a case has a lightly scored piston got a air leak needs to be torn down and redone.
P.M.P.
Stiff Member
12:29 PM
Michigan
Guess most haven't run a ported 357? It doesn't take much to make big gains over stock. Hell of a saw!!!
I Never ran one. I have opened it up a little deleting the base need to update the other thread on it.I ended up getting another jug and piston from spike to have while the gettin was good.Figured if I screwed the one up what the hell. Can't wait to run it.
