usmcbuckwild
Buck
- 1:07 PM
- Dec 24, 2017
- NW CT
Flywheel side seal
Let me check the garage. I know I have 22xx seals I got by accident.
Flywheel side seal
That would be an awesome stroke of luck. For a very unlucky saw.Let me check the garage. I know I have 22xx seals I got by accident.
32:1 is leaner mix than 50:1I’m also wondering, maybe these carbs are designed to adjust to 50:1 mix and some oils may be too thick for autotune/mtronic to calibrate to at richer 40:1/32:1 ect. Add the mods/porting on top of that and it screws up the adjustments? Then they need a re calibration? Just thinking.
Rustoleum grill paint.
I believe it is the one on the left but if you don't mind please send them both to @rattler and let me know a price.
Thanks
My 562 and 661 are running on 12.5 to 1While we’re on subject of 5 series saws, my 2253 was starting to act like it was flooding itself (off idle bog after 10 secs) as it must’ve thought the mods i did to it were a massive air leak... had to remove the little brass plug and 1/4 turn ccw. Problem solved and the lightning fast throttle response returned. It was getting worse with more run time after I did the mods.
My 562 has zero problems modded the same way as the 2253. I think the 562 has a zama and the 2253/550 a walbro. I do think the way the autotune runs is a little better on 562 for some reason.My 562 and 661 are running on 12.5 to 1
They aint exactely "normal" and I dont have any problems
I'm pretty comfy right where she is now ............. you can see in the CT gtg videos, there aint no mosquitoes near muh sawsAt this rate you'll be 1:1 by winter.
Lol
