- 4:14 AM
- Feb 26, 2017
- Belleville, Ontario, Canada
What's on my bench? A test of wills I would say, and an education in aftermarket cases.
I have been trying to put my 272xp back together after having a bearing let go last spring. I needed new cases, so I bought new aftermarket Huztl cases. Got a used crank, new meteor piston, ass't. oem brg.s, orings, gaskets, seals. Put the new (used) crank in and discover it's bent. Order a new (used) crank from jockeydeuce and install it - it's good. Go to install the oil pump and it won't go - the casting it too thick in one place. Get out the dremel and burrs. Go to install the oil vent - the hole is too small and there is no extra meat in the casing to allow a bigger hole. Fab up a CJBrown vent. Flip the saw over and install the flywheel - it rubs on the case. Dremel. Go to install the the fuel line grommet - the hole it too small. Drill. Install the fuel tank - it fits! A miracle! Install the coil - nope. Dremel. Install kill wire grommet - hole's too small. Fab a grommet. Wrapped the end of the loose con rod and set the cylinder on the case. Give the recoil a tug - no spark.
Head back in the house and type therapeutic post on OPE just to calm my nerves. Will pick up where I left off tomorrow - stay tuned...
