Redbull661
661 hoarder (BlueBallz)
9:35 AM
MN
so if you've been following my take downs you know super techniplate made a giant mess of the saw in just 4 tanks and been trying to get it clean ever since.
Previous take down: schaeffers 5 tanks 25:1
this take down: red armor 5-6 tanks 40:1
previous takedown schaeffers 25:1
this take down Red Armor 40:1
some thoughts...
- red armor does seem to clean things. I do think schaeffers does it better though.
- red armor is pretty impressive as far as residual oil. I do think the red dye makes it look like there is more oil then there really is. I am impressed at what is left at 40:1 vs what was left with schaeffers at 25:1.
- I noticed that the red armor residual seems to be gooey or sticky rather than what the rest have been like...oily?. Is this good or bad? I don't know.
- there is more crusty carbon on the exhaust side top of the cylinder vs the schaeffers so that is a bit concerning. But there seemed to be less of this problem when I ran 32:1 (see below link)
***edit: incorrect. see few posts down from this one***- there seems to be more build up on the top of the piston than what I started with.
- I've been running 28" 8pin 404 full comp on everything. So a decent load. I don't think I would run 40:1 again with that load on the saw. I'd probably go back to 32: or 36:1.
- here is link to when I ran red armor 32:1 but it was right after the klotz supertechniplate sludge. http://opeforum.com/threads/what-oil-is-best-and-what-ratio.98/page-354#post-153597
- I guess I am thinking there isn't much point to these take downs anymore unless the load and ratio is consistent. I'm thinking a 36" bar 404 full comp and 32:1 across the board.
- and to eliminate some - seems the best idea would be to do the oil test and take the top 3-5 performers and run those each for 8-10 tanks with the 36" 404 full comp and then take em down.
- attached below some more pics from this take down (40:1 red armor)
Jlgholland
10:35 AM
Ohio
I've been running HP2 @ 32:1 and I plan on sticking with it permanently. Thanks for the testing redbull
Redbull661
9:35 AM
MN
Correction - I said the piston top looked like it had more build up on it. That is incorrect.
I scraped a bunch off prior to this picture. So this is the "start value" if you will... how it looked BEFORE running red armor 40:1
this is AFTER running red armor 40:1 5-6 tanks... the carbon layer is thinner for sure and no doubt more of the piston is clearing up. (look at the edges of both pics. Anyway still good stuff. Just don't think 40:1 was ideal for the load I was putting on the saw. And I will say the saw ran good using it. Very curious to see how it stacks up against others in the oil test.
Nitehawk55
10:35 AM
Ontario
I have to agree with mdavlee , I just can't see the need to run a saw at 32:1 with these modern synthetic oils or even dino .
Myself , from what I've seen (in my time) is 40:1 is plenty , 50:1 OK too in most cases of average use and if using a known good synthetic oil .
With M-tronic and Auto tune saws I think 32:1 is too much , I feel it probably over taxes the control unit causing possible bad metering.
That's just my thoughts on it guys , not preaching to anyone .
I'm old school ;)
CR500
10:35 AM
Western NY
Maybe lower viscosity ia better at 32:1 like GP7 or 2r vs a high viscosity like R50 or Motul 800
I tried 50:1 a while back and it looked okay with Benol, however after that I went back to 32:1 just because old habbits die hard.
I probably should try 40:1 in the 661 but everything else does not mind32:1, that may change if I can get a euro coil though.
40:1 did look good in the 441 when I got it back in 2011..... now you have me thinking lol
Nitehawk55
10:35 AM
Ontario
I wonder what results would be stock saw VS ported ??
hseII
Heef
10:35 AM
West Georgia
I'm interested to see the results of Sabre & Red Armor in non tronic saws to know whether to run 32:1 or 40:1 like the sticker on my saw says. [emoji8]
stihl saws
You can always justify another saw.
10:35 AM
Virginia
I did it again.
Can you add an * or something?
Haha! The primers came from Dino-Nobel. Honestly, when I picked the name I didn't know there was a stihl sawing.
hseII
Heef
10:35 AM
West Georgia
Yes.
The teeth on his 2nd hand saw were taken from a 1 legged Pterodactyl.
The Pterodactyl lived another 25 years after the extraction.
