What? No bandsaw milling threads?
EFSM
5:12 PM
Extreme southern IL
I would buy an extension, mine was standard and will cut 10’2” but it’s tricky. I was going to make my own extension but they mill the top of the angles square and it’s odd hight so it will be more of a pain to make my own. Otherwise it’s 200$ or so more for one now than when I bought mill just from separate shipping ect. I set the trailer up for one extension so I can cut up to 16’
I agree. Our HD36v2 Norwood will mill a little over 16' but it makes it so much easier to mill shorter (12-14' range) logs when you have plenty of bed. We just milled a white oak log that was 14'6'' and about 28" in diameter. Talk about a chunk! The heartwood cant we got was 14x17", after cutting some boards off the outside.
5:12 PM
Just added an extensions to our woodland Mills bandsaw. They had a free shipping promotion which made it appealing.
At the same time I found some angle iron that would work great for a diy extension.
Guess I will use them if I need to cut past 16 feet…
I'm considering an addition to roll my mill head back on so I can cut longer logs.
lehman live edge slab
Live Action
5:12 PM
Mn
Does it have a flat milled leg. I believe that is kind of important for both rolling resistance and straight cuts. The wheels only contact the corners of the milled surface so if it has a round edge like normal angle it will push probably a bit harder. Just looked for an extension for mine and it’s 409$ plus 199$ shipping so I’ll need to figure something else since I was stupid and didn’t order one with mill.
Fleethirte
6:12 PM
Virginia
Can’t you cut 20 foot allready?
Just adding a little at the end or beginning for the mill rig to slide on would add a few feet.
I find it interesting the two end pcs are missing the stainless steel top and thus are not level with the rest
5:12 PM
16'11" is what it is supposed to cut. I'd like to be able to roll the mill head back 4' so I could better use the whole bed.
Fleethirte
6:12 PM
Virginia
I think my clutch is failing on the bandsaw mill. Any one have any experience with it?
Blade has been stopping in the cut. New blade in pine. I just kept tightening the tensioner but it kept happening. Today I had belt like smoke coming from mill.
What would cause the clutch to fail?
I will check the bearings to but at least the tensioner side wheel feels fine.
Any ideas fellas?
5:12 PM
Any ideas fellas?
Sure it ain't the belt?
Fleethirte
6:12 PM
Virginia
I am actually leaving twords to much tension.
I loosened it up so I could spin everything freely and everything by hand seemed fine…
Put the tension back on and it cut….
I also tightened up the plastic shims that clamp around the square mounting posts that allow the mill head it to be raised and lowered.
Now my only problem is that I feel like I have to push harder than I should. I put a new blade on for this log so I feel like it should cut a lot easier.
5:12 PM
My drive belt became a little loose at 25 hours or so. Took me a bit to figure it out. Also....engine rpm can get too low as the cable stretched. That caused problems till I figured it out too.
Fleethirte
6:12 PM
Virginia
I just tightened the throttle as well. I don’t think my father in law had it going to full throttle since day 1
I need to check the guides that sandwich the blade. I haven’t looked at those at all
thedude74
Bonafide & Stuff !!!
3:12 PM
Alaska
I've had to tighten my throttle cable a few times as well.
The auto lube valve sticks once in a while. Not a big deal with water. Been running a 50/50 mix of window washer fluid and water through the winter.
What blades do you guys prefer?
I switched from woodland mills to woodmizer. Initially the wood mizer blades are sharper but don't seem to really last any longer.
Fleethirte
6:12 PM
Virginia
i have only ran the woodland mills blades. i have some wood mizers i’m looking forward to trying.
if you go back in this thread a bit, i think mastermind is using blades called resharp or something like that….
