What did i buy? (no china content) serial help!
Basher
12:54 AM
Canada
It has next to no fuel or oil resistance, the paint will dissolve and peel very quickly. Only paint I have seen hold up on saws is automotive 2 or 3 part systems, expensive and harder to work with but worth it. Of course powder coat is the best.
popopboat
5:54 AM
So its not really worth it repaiting it for look. Best to keep it this way i guess
Basher
12:54 AM
Canada
Most just leave it as is unless it`s only for a show piece.
popopboat
5:54 AM
just was thinking it might increase price for selling a bit lol
also, how much ohms should i read on this coil (066), im reading 12.5 kOhms
popopboat
5:54 AM
Do you know by any way which powder is best to use to coat it? and inside of crankcase also.
popopboat
5:54 AM
There is a member on here that could answer your question much better, @Glock37
Lets see if he can chime in.
He might not be present, or doesnt want to share his secret :biggrin: hehe
Im looking at polyester, or silicon based-high temperature ( but is it really needed 300+C°), cant decide :nusenuse::confundio1:
popopboat
5:54 AM
What are u wanting the powder for
The powder we use is good for 800 f
We dont do silicone
I'd like to repaint this crankcase, as it looks really bad :/ , also there are few peel-offs inside of the crankcase and i dont want it to peel of and ruin the cylidner/piston completely.
As we are only 5000miles apart, i cant bring it to you :biggrin:
I want to try it myself, or even if i find someone who does powder coating here, i must tell which powder to use firstly.
And that is what im interested in the most, which powder should i use, epoxy or epoxy-polyester or ... some other type.
popopboat
5:54 AM
*This is just a joke* *This is just a joke* *This is just a joke*
popopboat
5:54 AM
How much of play can bearings have?
I took it apart and engine only needs new oil seals, bearings are completely smooth, have a bit twist and side to side play, but no up and down.
Have to fix crankshaft threads, and repaint it and hone cylinder a bit.
And maybe 30-40$ in cosmetics and it should run well.
But JESUS, that flywheel was stuck as f*ck, was literally shaking while tightening flywheel puller with two 10 inch wrenches.
popopboat
5:54 AM
Could anyone tell me how much clearance is "-okay" for 064/066 cylinder, lets say when pressed one side to the cylinder walls, how much clearance should be on the other side between piston and cylinder?
