What compression testor for saws with 10 mmm plug are you guys using?
Lone Wolf
1:40 AM
Nj
The most recent batch of OEM echo / Shenandoah compression casters I received accidentally included the 10 mm adapter with each one and the distributor told me to keep them so I am including them for freewhen you buy them right now
Is the Scrader valve at the tip of the adapter?
Lone Wolf
1:40 AM
Nj
Price?
Lone Wolf
1:40 AM
Nj
Update I still cant believe the compression tester setup I have for 10mm plug is accurate. Everything in my shop now reads about 130 PSI . I feel it should be at least 150-160 . WTF is the deal with this thing?:BangHead:
Manofstihl661
1:40 AM
Texas
Hmmmmm and you know it’s not the gauge I’m assuming because you do plenty of work. What were you getting before?
Lone Wolf
1:40 AM
Nj
90 with the adapter 130 with the Snap on hose ! I use 2 gauges and both read the same. I also get great readings with the 2 gauges on 14 mm plug size cylinders.
Lone Wolf
1:40 AM
Nj
Only thing I can think of is the thinner hose over a distance produces a friction loss.
Manofstihl661
1:40 AM
Texas
Hmmmm got me stumped. I could see what your saying with the longer lines. I feel like mine low blows a tad bit but like you it’ll read the same across 2 gauges
Lone Wolf
1:40 AM
Nj
You have the same basic snap On setup and are getting the proper compression from a test I feel I am not. Scrader valve maybe at a different distance than yours? Maybe post pics of both our setups?
Manofstihl661
1:40 AM
Texas
Yeh when I get home later I can do some tests and take pictures. I have an older model snapon and newer model. Head units that is.
Lone Wolf
1:40 AM
Nj
Both should read the same. I am convinced it is not the 2 gauges I have for sure . They work fine on the 14mm stuff.
Lone Wolf
1:40 AM
Nj
See anything that would cause a low reading Threaded end depth 10mm IMG_2294.JPG
Lone Wolf
1:40 AM
Nj
psuiewalsh
Basement Bodging
1:40 AM
Nottingham,pa
How does that compare to length on the 10mm plug? Is the plug longer so it takes up more cylinder space?
