Well used 372 - wanna rebuild questions
beaglebriar
The Peanut Gallery
5:56 AM
Warren Center, PA
That’s what i will do - i need info on how to clean up oem cylinder - i have that ball with fingers ( forgot the name) used for cleaning up cylinder and i have a regular hone. Suggestions welcomed and also where is best place to buy meteor piston rings and a good open muffler. Tell me about deleting gasket - literally just leave it off and put nothing under cylinder ?
Piston- https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/181764181950
Base gasket delete sealant- https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/172366134240
Don't try using permatex/silicone it isn't the same thing.
Muffler mod-
5:56 AM
Scott chandler
5:56 AM
North Carolina Advance
Fellas if saw is stock then it should be 50mm cylinder ? And tell me where i can find year it was made and wanted to ask opinions on the 52mm pop up that hyway has. Not sure if that’s wise or no. I would like for saw to hold up but a little more power be nice. If the cylinder holds up as well as oe ? Or any mods needed like intake. If so i will just go back stock - new seals new intake rubber and new fuel oil lines and some new plastic new muffler with a new p/c or at least rings. Will leaving gasket out from under cylinder make that much difference ?
5:56 AM
If the cylinder will clean up, use it. The AM stuff doesn’t run as well as the oem, even if it’s 2mm bigger. If you want it better, get it ported
cuinrearview
Handy dood
5:56 AM
Dowling, MI
