Redfin
Meh...
- 11:23 PM
- Dec 24, 2015
- Central Pa
I have no idea what a high tooth chain means. Is it truely just a taller cutter? Whats the benefit?
High tooth is just what it sounds like. ..the cutter and rakers is twice as tall. ..and only one source to get it....about 3.00 a driverI have no idea what a high tooth chain means. Is it truely just a taller cutter? Whats the benefit?
Semi skip for you...That was a sweet run. I think I need to pony up and buy a tall tooth chain.
Sent from my XT1585 using Tapatalk
Better chip clearance?High tooth is just what it sounds like. ..the cutter and rakers is twice as tall. ..and only one source to get it....about 3.00 a driver
lordy !!! just watched this, the title made me think it was a husky 350
just Frickin WOW!! unbelieveable
WOT out of the cut must just be insane.
You sure you have enough?Yep...and very aggressive. ..takes alot of hp
It takes a while....it comes totally unsharpened when it is new....but there is plenty of room to do whatever you want with the fileWould be soo awesome to file.
Almost.....is there such a thing as too much? LolYou sure you have enough?![]()
I wonder how narrow a man could make that stuff?It would be easy to file. I like that 1/2" stuff I filed for Lee
I'm sure, sorta like power shifting, your right foot is never supposed to lift (hard to do, lifting the right foot when you push down the left is like reflex).
Power, no. Control, maybe.Almost.....is there such a thing as too much? Lol
The biggest problem I'm having is having the balls to hold it wfo...
