Frankh
- 8:46 AM
- Jan 31, 2020
- Otsego county, ny
I just put a new Hyway cylinder kit in my 272xp, new seals gaskets, vac/pressure test, pre lube piston. After half a tank of gas, I lost compression and found scoring. I use amsoil synthetic at 50:1. The starting needle settings were one turn out. My other 272xp went through a Hyway kit after half a dozen tanks. The nwp kit lasted a few years, which I'm ok with.. Am I doing something wrong? Here're a few pics. You can see the scoring all over, including the mark from the ring gap pin on the intake side. Any help is appreciated. Btw, I use my saw almost every day for one tank each day.
Thanks
Frank
Thanks
Frank
