Wanna learn to Port a Saw
8:09 PM
What the shaft diameter on those and whats was the key word to find them?
I just use a dremel they fit perfectly I've never messed with the foredoms i was told they take a different size i don't know somebody will correct me.
7:09 PM
Dremel has two different sizes but if they fit that all that matter and I think its 1/16 or 1/8 I bet thkse are 1/8
Moo's Yo Daddy
8:09 PM
Da Barn
How do I sand the base with the cylinder extension?
Will a belt sander and slow rotation work?
Also, "cutting the band". Can I do this with a wood chisel? Then sand afterwards?
Seems a bit more complicated than I thought originally.
Pincher
7:09 PM
sw corner of twin cities mn
Looking back at my first "porting attempt" I wish I would have just cleaned things up a bit and smoothed out some casting flaws, set squish at .020 instead of what I ended up with that will not be mentioned. It seems you want to run before you learn how to walk. Be patient and do your homework, there is a lot of free information on this site!
