Ktoom
- 7:33 AM
- Jan 28, 2016
- Albany, NY
Hey guys, are these carbs finicky to adjust? Im working on a older 026 thats has one. When i go to adjust the H screw past one turn out, it practically kills the saw. Ive already put in a carb kit and done a leak down test on the saw. Found no issues with the leak down test. Tested the carb and it doesnt leak after the carb kit. Also the fuel tank is venting properly. I already replaced the fuel line, impulse line, fuel filter, air filter and spark plug. I tried a new Walbro WT194 on it and it ran a little better. The saw runs good with the L side at one turn out and the H at 3/4's out. Any thoughts?
