Velocity stack
Jughead
8:36 AM
Do it help the performance at all. The main reason I'm trying to find something is for performance. That is a cheap price though to bad they don't make them for bigger cc.
seemed to help a little bit.
skippy
Husqvarnas Sawyer
8:36 AM
Pennsylvania
I understand air filters are very restrictive
ft. churchill
5:36 AM
Along the '49 trail in Nevada
A couple of my saws have them. They were on the saw when I got it. I remember saws from the early 80's having them or "green weenies on them. They were quite common.
ft. churchill
5:36 AM
Cleaned up, muffler mod, and a new throttle lever to replace baling wire and this saw runs outstanding. Part of these two saws performance is the bigger air filter and velocity stack.
SteveinUT
Have gun - will travel
6:36 AM
Southern Utah
Here's mine. To be honest, I don't know what difference it made, because the saw had a v-stack on it when I got it and I don't have the parts to return it to factory configuration.
ft. churchill
5:36 AM
The reason you see this sort of filter set up on these early 80's saws is that it made more power and was easier to clean/run longer between needing to be cleaned.
Funny how I dont have my original parts either. People threw out the stock filter parts as these set ups were better than factory.
Nice saw.
tallfarmboy
Jack of All Trades... Master of None...
7:36 AM
Jasper, MO
I would like to know if this makes any noticeable performance difference. I know there will be better filtration and perhaps better flow, but has anyone ever dyno'd a saw or did some timed cuts?
TFB
Jsk
8:36 AM
Avoca michigan
They all look really cool with thwse setups. Does the maxflow setup have a different intake? they look like they will filter good and still flow alot of air.
