Unlimited coils
heartwoodlover1001
3:04 PM
Beautiful Michigan
A question for you good folks, kinda new to the world of saw modifications. The benefit is: increased RPM that correct? The danger is engine meltdown!?
Is that a proper way to view such a modification? On a saw that is designed to operate near ten thousand like a 272, if pushing the upper limits of 12/13 plus, is it the design i.e. the piston cylinder crankshaft that can't withstand those increases, could someone explain the the process as a whole. Are their mechanisms that allow for this modification to be done Sager? Less safe?
For instance if a saw has a heavier piston option does that minimize the risk. Could some members discuss the specifics at play, experience, happiness/unhappiness.
Thank you so very much. Have a great night.
P.M.P.
Stiff Member
3:04 PM
Michigan
Having a ported saw means it runs more effecient so it will run turn more rpm's as a result unlike stock .Having a unlimited coil helps get the full potential out of it.That way it can be properly tuned.A ported saw can be tuned to more or less as far as rpms go.
A stock 272 - 13,500 RPM not 10,000
jmssaws
Banneded
2:04 PM
Porting in most cases not only adds overall power but moves peak power up in rpm.
If your stock saw makes peak power at 9k then after porting it makes peak power at 10.5k and that creates chain speed and that's all any of its about.
The only way for it to cut faster is to turn the chain faster
jmssaws
Banneded
2:04 PM
A heavier piston will absolutely shorten the life of the saw.
Lighter the better.
Nothing lives forever and saw parts are cheap.
Most broke or blew up only need a piston and that's cheap and easy.
If your stock saw turns 9k in the wood but after porting it turns 12k+ with the same setup then it most definitely will have a shorter life,maybe knock a month or 2 of the life of a production saw and a weekend wood cutter won't wear it out
Tune,dull chain and 99% of the time the ham fisted goon running it is what kills them not porting. A very small percentage of saws sold will ever be wore out.
Stock saws break too and when does the manufacturer usually gets the blame but when a ported saw breaks regardless for what reason,it's the porter that gets the blame and most of the time he fixes it for free to save face
How long should a stock saw last?
How about a ported one?
Coltont
3:04 PM
Pennsylvania
Lighter the better.
I have only ever granaded 1 660 in ten years of cutting timber. Religiously keep the chain sharp and try not to rip on them when they are pinched. They will last a long long time. I've got a 660 that I'm still running that's got a couple million feet of timber on it. I'd say it's still at 90%.
jmssaws
Banneded
2:04 PM
They are way tougher than most think.
Lot of guys pull the muffler every tank and search with a magnifying glass for a tiny scratch and when they find it,it's a full tear down for bearings and seals because it must have a airleak.
Coltont
3:04 PM
Pennsylvania
Lots of people don't like the hd2. Say it lets through to much stuff. The 066/660 is not affected by it at all.
pro94lt
2:04 PM
South
LOL that's the truth.
3:04 PM
I've seen scratched Pistons make 180 lbs of compression. I have one from a 460 I used when playing with methanol/nitro. Few scratches and cleaned up with Scotchbrite and it still makes 190-200 with a little machine work.
jmssaws
Banneded
2:04 PM
If I can find the piston out of my 562
I'll post a pic of it and a video of it running it
