- 11:15 AM
- Jan 20, 2016
- NE OK
Are you talking about owning only two saws? Or like Husky guys owning aeven but only two run.2 saw plans are tough. If I could always have the ideal size wood, my plan would be 346 and 064, ported of course. The most practical would be what @drf256 suggested. There are some big trees around here, it is nice to have a big saw.
There's that Echo advertisement from a few decades back where it's a 30-40cc model **supposedly** solely used to cut a 3-4' dia redwood on a logging job.Owning two saws? Heavens no. I always have three in the truck when going to a job. Husky guy you know.bunch more at home but my running to non running ratio is quite good.
I’ve told the story before but I once felled a 30” tree with a 14” top handle because I broke a bar in one saw and the other’s spark plug insert came loose.
I have a 543Xp in Kevin’s position as well, I already have an XS 346 variant and love it. I ran Woodpeckers 543 and it was impressive, I cannot wait to run them side by side.I'm in line for a 543 XS-job.
Someday I'll find AND be able to afford a 346xpg or 353G, maybe then.....never ran a 260/261, but I like the 024/026, save for the vibe-mounts.
462/500 for felling here. 395 with a 36” semi chisel for bucking-there really is no substitute when you just need to get it done.
I just can't get a liking for semi chisel in any pitch!If I was living in a fantasy world it would be a 346xp/353 with an 18" and a 390xp or 056mag with a 28-32", 3/8" semi-chisel all day
This! Exactly why I separate the felling and bucking tasks with different saws. A felling chain I will wear out by filing it down until I lose teeth in the cut. A bucking chain’s life is dependent on a lot of factors, but usually gets abused.I use two saws more to preserve my felling chain as I like to spend a little extra time getting it perfect.
True!!!I will say the big fast saws with aggressive chains and short bars require more caution in regards to kickback.
MS 400 & MS 661.Two saw plan, what is that?
PS-9010 half wrap & PS-9010 full wrap
or
PS-7900 20" .404" & PS-7900 20" 3/8"
or
PS-7300 & PS-7310
or
PS-6400 & PS-550
or
PS-6100CE & PS-6100 MMWS
or
PS-460 (stock but turning 15k) & EA5000 XS
or
EA4300 & PS-4600SH
or
PS-3400TH & PS-311TH
or
SD 105 & SD 103
Simple really!![]()
In dirty, snotty wood (storm damage) full-chisel can dull in 3/4 of one cut, semi-chisel can last 20+ cuts, I've had it last about 40. I'll be getting chipper chain to run on a hard nose bar next week. Yes, it's slow, until you don't have to stop to change out / sharpen chains.I just can't get a liking for semi chisel in any pitch!
Does it work?
Yeah???!!!
Is it satisfactory fast cutting?
Heck no!!!
To me semi chisel is so underwhelming in performance I have sort of an hatred towards it.
Maybe I don't know how to sharpen it?!![]()
I got .404" chipper for nasty stuff.MS 400 & MS 661.
In clean wood speed is the king.
The only Stihl I am interested in is MS880 simply because a Dolmar 166 is out of reach.MS 400 & MS 661.
