Trouble with an 026
Khntr85
8:37 PM
Indiana
I rebuilt a Stihl clamshell(can't remember model now), and the AMbearings failed on the very first cut, boy was I pissed, lesson learned!!!!
stihl_head1982
Here long time
8:37 PM
USA
Usually on the clamshells you can pick up some really good quality aftermarket bearings at your local bearing supplier. Just google "bearing supplier near me" and you'd be surprised. I found out about a few suppliers I did not know were in this area.
jmester
8:37 PM
VIRGINIA
Have you looked into your carb? A saw that has been run then parked for a while the diaphragms will get stiff. Do you run pump gas or fancy fuel from a can. If you are running pump gas you may want to check the inlet screen in the carb. Have seen then build up a white film that will impede fuel flow. You will need to shine a light from the back side to see it as it looks fine with out the light.
Khntr85
8:37 PM
Indiana
Hey thanks for that, I will be looking for places on the net here in just a bit.... that would be nice to find a local bearing supplier!!!!
